0 members (),
119
Mod | | | Forums66 Topics128,088 Posts1,056,416 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 47 | Calling all Quadrajet gurus...trying to set up a 750cfm qj on mildly modified 350..10:1, mild cam(15" vac),turbo 400..stock conv.,3.08 rear..sugestions for jetting/metering rod/hanger. Ran pretty good with 600 Holley with out of the box jetting. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Simple question, but a VERY involved answer.
Rochester made 100's of different quadrajets set up for different applications. These have many DIFFERENT airbleeds.
One would need to know the EXACT quadrajet you are trying to use to come close to a recommendation.
There is now an excellent book (also very inexpensive) on the market concerning the modification of quadrajet carburetors by Cliff Ruggles. Publisher is SA Design. Check your local bookstore.
Very best book on carburetors for the lay mechanic that I have read in 45 plus years of working on them.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2006 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 47 | Jon, thanks for the reply. Carb # is7045589('74-'77 CA Chevy/GMC).I have Ruggles book on order...been studying Doug Roe's Rochester Carbs(HP Books). Reduced the tension on the secondary air valves by 1/4 turn and swapped hangers from D to J. Improved response quite a bit. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Ironhead - the California Q-Jets are not generally the optimal unit to modify, as many of them have massive airbleeds.
Reducing tension may have worked for you in this instance, but the fact that it did work may be indicative of other problems. Generally, reducing the secondary airvalve tension will create a "hesitation".
Play with this one until you receive and read Cliff's book, but I think you may wish to later do some ebay shopping for a different starting point. The Federal carburetors tend to have smaller airbleeds than their California cousins, and the mid to late 1970's Chevy cores are not that expensive.
