6 members (Nick in Manitou, TooMany2count, wilbur53, walter74, 2 invisible), 74 guests, and 0 robots.
Topics128,076
Posts1,055,920
Members48,429
#338671 11/18/2007 4:58 PM
I've got a '46 1/2 T Panel with a norrowed 9" under it. The PO has a home built 3 Bar set up in it and it rides, well like a darn truck, really hard and stiff. I'm thinking about either a 4 Bar parallel or ladder bar both with coil overs. Which one do you think would be better or easier to install and adjust.
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
IMO 4 bar
The link setup isn't what's making it ride harsh, it's the spring rate. You'll want a lower spring rate to soften the ride. As far as installation, the ladder bar would be the easiest. But I agree with BC52, go with the 4 bar, or better yet, a triangulated 4 bar, for better control and tuning.
Bill Burmeister
Went with ladder bar and Vega coil springs. Rides nice but if I had to go over again with it, I'd go 4 bar...it looks cleaner and doesn't hang as low.
