1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | I've got a '46 1/2 T Panel with a norrowed 9" under it. The PO has a home built 3 Bar set up in it and it rides, well like a darn truck, really hard and stiff. I'm thinking about either a 4 Bar parallel or ladder bar both with coil overs. Which one do you think would be better or easier to install and adjust.
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The link setup isn't what's making it ride harsh, it's the spring rate. You'll want a lower spring rate to soften the ride. As far as installation, the ladder bar would be the easiest. But I agree with BC52, go with the 4 bar, or better yet, a triangulated 4 bar, for better control and tuning.
Bill Burmeister | | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | Went with ladder bar and Vega coil springs. Rides nice but if I had to go over again with it, I'd go 4 bar...it looks cleaner and doesn't hang as low. | | |
