1 members (UtahYork), 128 guests, and 4 robots.
Topics128,186
Posts1,057,318
Members48,469
Hi All! I'm happy to say that I'm a new member to Stovebolt.com and I'm working on a restoration of a 1951 Chevy 5-window. I have heard that you can use a Chevy S10 EXTENDED frame and tranny in a 1951 restoration.. is this true? Any advice? Would appreciate any help.
I'm working on 1953 Chevy 5-window restoration and I'm looking to keep the 235 and 3-speed tranny in place. We were able to get the 235 to run and I've since taken it to a machine shop for a more thorough look. I've been told that the engine will require a complete rebuild and cost approximately $1500. Is this reasonable? Could I have the machine shop do the machining work and then buy a rebuild kit and have a mechanic friend do the rebuild? Looking for experience and recommendations here! THANKS!!!
You should google "advanced design engineering" they have a kit for the conversion you are talking about, lots of info also. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Apprentice
Apprentice
Use the search button here and search the HAMB too. There are a number of articles on it. One thread on the HAMB has a link with about 40 pics in it.
Basics are use a standard cab long bed frame.
$1500 seems steep for the whole engine. Have them do machining only.
1949 5 Window 3100
First off, welcome aboard!
Actually, no you can't use an S10 frame in a 1951 restoration.
Look up restoration in the dictionary and you'll see what I mean. wink Not really trying to bust your chops, but the word restore gets used kind of loosely these days and I think the few guys that actually do restorations deserve some recognition.
The S10 swap is popular and a search in the hipo shop forum will turn up a lot of info.
Best of luck with your project.
Steve
'49 3800
'52 3600
'57 3100
Well said Steve, and thank you!
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Appreciate the insight and agree that I misued the term "restore" in this case. I certainly appreciate the difference between a true restoration and a rebuild as I've seen many of both. Thanks again for your help and advice.
Ticky, ticky, ticky!
I suppose I should also use my experience as an English teacher to correct everyone's grammar.
I think we all get all the recognition we deserve when we finish our restorations or whatever you want to call it. ChevyTruckKy welcome to the bolt and enjoy your ___________. Send pictures, we like pictures...
~Jim
First off, welcome
Next, there are many choices for your '51. Many dependent on your skills, time, money, and ultimate end goal. Restoration vs Resto-Mod vs Resto-Rod vs Rat Rod vs..... Stock ride height, lowered a little, lowered a little more, slammed.
Below are some examples of frame swap and/or suspension:
Using the S-10 frame with 2" front wheel spacers in front and an S-10 4x4 axle out back (S-10's have a 54.5" track width, your 51 is closer to 58") From there, there are two choices
1.) Using the AD kit
2.) Using your own fabrication skills
Using a GM metric frame (El Camino, Malibu, etc. All have 58" wheel base) I have only seen one AD on an El Camino Frame
Use existing frame and add IFS (no particular order)
1.) Weld in or Bolt in Mustang 2
2.) Bolt in AMC Pacer
3.) Bolt in Narrowed later model GM truck suspension
4.) Weld in or Bolt in GM metric front suspension (more on that later)
5.) C4 Corvette suspension
Make your own frame, add whatever suspension you want
It was once stated , "There are two kinds of people, those who weld, and those who dont"
