| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33769 03/16/2003 5:05 AM | Joined: Mar 2003 Posts: 30 Junior Member | | Junior Member Joined: Mar 2003 Posts: 30 | I am new to stovebolts so here I go. I am going to put a 10 lug rear from a p series chev {width is same,wheels bolt on} just move spring perches. Same donor truck th400 w/parking brake. Power will come from 292 with new motor mounts/brackets,so power steer can be added to orig front axel.Stopping power is from rotors from late model tahoe with center hole bored out {stud pattern is same as orig drum]I need to find or make caliper mounts.Also want to replace front wheel ball bearings with taper roller bearings.  | | |
#33770 03/16/2003 5:39 AM | Joined: Feb 2003 Posts: 25 Member | | Member Joined: Feb 2003 Posts: 25 | I HAVE BEEN WANTING TO DO THE SAME, BUT THE CALIPER BRACKET HAS BEEN HOLDING ME BACK. MY REAR HUBS DON'T AUTO ADJUST SO INSTEAD OF PUTTING NEW DRUMS I JUST WANT TO PUT ROTORS. DO YOU JUST PLAN TO CUT FLAT METAL FOR THE BRACKETS OR PURCHASE THEM? | | |
#33771 03/16/2003 6:43 AM | Joined: Mar 2003 Posts: 30 Junior Member | | Junior Member Joined: Mar 2003 Posts: 30 | was hoping to find sombody that makes the plates if not I have a fab wizz that will make them. allready putting in drive train.  | | |
#33772 03/16/2003 7:12 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Winky,
What's a P series Chevy truck? I see in the '79 Chevy service manual that they were available with 5/10-lug disk brakes front and rear (14" rotor).
I'd like to use that set-up on my '38 1-1/2 ton but don't know what to look for in the wrecking yards.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
#33773 03/16/2003 8:09 PM | Joined: Mar 2003 Posts: 30 Junior Member | | Junior Member Joined: Mar 2003 Posts: 30 | p series are like ups trucks ,potatoe chip trucks, most have alum body. Easy find in truck boneyards  | | |
#33774 03/16/2003 8:16 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Winky,
Thanks for the info. Weather is warming up and drying out so feels about right for a boneyard trip.
#33775 03/16/2003 8:38 PM | Joined: Mar 2003 Posts: 30 Junior Member | | Junior Member Joined: Mar 2003 Posts: 30 | has anybody changed front wheel bearings to roller bearings? I need interchange info from anybody? :confused: | | |
#33776 03/17/2003 2:12 AM | Joined: Mar 2003 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2003 Posts: 45 | Originally posted by OlBlue: Winky,
I'd like to use that set-up on my '38 1-1/2 ton but don't know what to look for in the wrecking yards. | | |
#33777 03/22/2003 3:08 AM | Joined: Mar 2003 Posts: 30 Junior Member | | Junior Member Joined: Mar 2003 Posts: 30 | Ok so I cant find replacement bearings to fit soooo... If I take spindles from P-30 5k lb front axle [same truck doner rear axle]use kingpins from f*** 4k lb axle [has same .922 dia] and bush the I.D. of the spindle bores to accept the bushings.That allows the use of the calipers,brackets and rotors and gives disc brakes and gets rid of the ball bearings.It allows the original 5 hole 20" wheels to be run [with the hub pilot in wheel bored a bit] and gives beefier steering knuckles and arms for power steering.  | | |
#33778 03/24/2003 4:55 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Some P trucks have independent fronts, some have I-beam if big enough. Seems with big wheels it should have I-beam, correct? AND, most times these are narrower than the same years of standard trucks. SO, if the spring perches are about right, why not use whole axle under old rig? Lots of times if you stay with same brands, dimensions like that stay the same for years.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#33779 03/26/2003 5:03 AM | Joined: Mar 2003 Posts: 30 Junior Member | | Junior Member Joined: Mar 2003 Posts: 30 | yeah i wish the whole axel would fit in, sure would make something easy. the doner truck i found is a school bus [short one like i rode to school in]has a straight axel in front that is too wide. thought about a custom tube axel but that passed quickly.next was bore out axel for larger kingpins,nix that idea-dont want to thin out ends of axel.so i think if i sleeve the spindle top and bottom and add a few shims to set the hight,i get modern disc brakes and taper bearings. I plan on driving this truck more than on sundays. Next I learned power steering comes from a 79-84 toyota 4x4 steer box that is a rare find cause its small and everybody is putting them old street rods. | | |
#33780 03/26/2003 5:46 AM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Winky- Sounds like a good plan, but I would make a quick check of the old and new axles and spindles to make sure they have the same kingpin inclination angle. Usually kingpins don't stand perfectly straight up and down, they tip in at the top alittle. So a marriage of old and new axle/spindles can work perfectly, or can possibly create a camber problem. | | |
#33781 03/30/2003 1:24 AM | Joined: Mar 2003 Posts: 30 Junior Member | | Junior Member Joined: Mar 2003 Posts: 30 | good point I thought they would be the same.anybody know where i can find kingpin angle specs? my spec sheets have about everything but that. | | |
#33782 03/30/2003 6:05 AM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Do you have both axles there? I would think once you had the kingpins knocked out of each, it wouldn't be too hard to check quick with a degree finder. Just something to check before you get started on a bunch of machining. | | |
#33783 04/03/2003 12:40 AM | Joined: Mar 2003 Posts: 30 Junior Member | | Junior Member Joined: Mar 2003 Posts: 30 | as soon as i can clean the doner axel thats just what will done.thanks for the tip barry | | |
#33784 02/09/2004 3:37 AM | Joined: Mar 2003 Posts: 30 Junior Member | | Junior Member Joined: Mar 2003 Posts: 30 | kingpin angles are the same. has taken almost a year to find an axel shop to retro fit my axel with newer spindles.just picked it up it looks great. they added spacers on top and bottom of original axel found f*rd kingpins .922 dia. the rest is simple simon. now i have my rolling chassis started. frame was sandblasted and rust preventer painted over the summer.looks like engine and front disc brakes time. need to take some pictures too. | | |
