3 members (Gray_Ghost, Mike34, Otto Skorzeny), 91 guests, and 3 robots.
Topics128,048
Posts1,055,664
#336203 11/12/2007 2:51 AM
Has anyone ever tried to restore a burned vehicle? I see what used to be a nice truck on ebay, but it's not pretty, lots of warped metal... potentially some of the parts might be salvageable... what do y'all think?
Another quality post.
Real Trucks Rattle
Rusty Rod #336208 11/12/2007 2:58 AM
That would be a tough if not impossible job. It would depend on how much sheetmetal is warped. You might be looking at nothing left of use but the frame, and it might be warped as well. I would run away as fast as I could from that job.
~Jim
I have tried to rebuild a 1996 chev Z71 pickup. I had more night mares with this project. The heat alone is trouble from the motor to the tail end. Heat & fire is not compatable to a good running vehicle. Once in the fire & heat will haunt you as long as you own the vehicle. Believe me I have been there !!
Hope this helps.
1 Offline
my advice on burned vehicles is if you can't inspect them personally and they aren't free, PASS ON THEM!
10 micron #336537 11/13/2007 12:46 AM
V
V Offline
As a firefighter, I've put out fires in many trucks. My advice is find a different truck. Those things burn really hot and there isn't much that is that goes untouched... They seem like a lost cause. Just my opinion.
With the paint being burnt off you also have to consider the metal would be pitted with rust. Not just spots but most likely all the panels.
38 original
48 panel
59 stepside
46 in the back forty
Highwayman #336717 11/13/2007 7:00 AM
when i get my photos back (on disc) i'll post two that got a little toasted during the san diego fires (harris fire). i'm down south working on the telecommunications network that got burned up.
i do know that fire and smoke damage cases rust, impurities in the metal, scrap all the upholstry and redo it, warpage in metal body work.
Jim & Caroline
What I was trying to say was that after the paint has been burnt off the bare metal is exposed to the elements like humidity and rain which is going to cause the body panels that have been burnt to be pitted with rust.
38 original
48 panel
59 stepside
Highwayman #337064 11/14/2007 2:56 AM
I would stay away from trying to fix a crispy critter. They are as bad or worse than a flood vehicle.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
Alan's 57 #337068 11/14/2007 3:14 AM
From an insurance point of view and old body man they come back to haunt you.
The crew that works on the \'42 --Sara, Hannah and Abby
dad6timz #337111 11/14/2007 5:27 AM
it's a 1935!!! all the wood is obviously gone... and there isnt much to the electrics.... or the interior for that matter.. i guess i should have brought this up front... doop..
i emailed the owner, and he hasnt replied.. i guess he either sold it, or is going to keep it..
Real Trucks Rattle
Rusty Rod #337122 11/14/2007 5:43 AM
Rust is... oxidation.
Fire is... really rapid oxidation. Even if you painted a burned truck immediately after the fire went out, there would still be rust under there unless you mechanically or chemically removed it.
Not to mention the warpage.
The 30's trucks relied heavily on wood as structural members in the cab. Restoring a twisted metal cab without the wood is an impossible task, you will have an easier task if you mine and smelt the iron ore yourself and then turn it into steel than starting with a twisted burned out hulk.
Paint & Body Shop moderator
Leo Offline
Moderator
Moderator
I remember when my car burnt in 1977. ('69 Chevelle) Nothing was salvagable.
Rusty Rod #338159 11/17/2007 2:41 AM
You're probally better off leaving that one alone.
Robert C.
I'm a Genius in the making.
1950 3600
