7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible),
125
Mod | | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | I bought this oil filter housing from a guy who said it was off a 1957 Chevy truck. Could you guys take a look at it and tell me if you think that's correct. I have never seen one with the type of attachment before. If it is correct, does anyone know what color(s) it should be? Any and all input will be appreciated. Thanks, Jeff. http://good-times.webshots.com/photo/2637172180100355167hGSbTp | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That is most definitely an oddball mounting arrangement Jeff. I've never seen one like that on any GM. Of course, I haven't been around as much as some of the guys here, so hopefully someone can ID it. The canister sure looks like an AC. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | The housing looks ok to me ,but the clamp is one I've never seen. But since there were many manufacturers for these filter systems,I don't think the clamp style should matter. As to color,I've seen so many colors on this site and up close and personal that it could just about be the "one" you like the most.
Drew
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I've never seen one with a separate clamp like that before, most of the ones I've seen have it as part of the housing. Maybe it's an industrial filter? Perhaps for some sort of construction or ag application.
Bill Burmeister | | |
