| | | Forums66 Topics128,109 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33550 06/07/2002 8:12 PM | Joined: Feb 2002 Posts: 61 Member | | Member Joined: Feb 2002 Posts: 61 | 1950 GMC 1.5 Ton Truck with the 248 I-6
Went to go start it and noticed it needed water.... but when filling, water came out of water pump shaft. (New pump, right).
Okay, local NAPA says they can get new pumps for about 120.00 BUT they said that the book only goes back to 1954 for the 248. Now, will the 1954 water pump fit on my 1950????
I want to put a 'new' one one or get one w/out having a core charge (since I'll have the old one rebuilt as a spare).
Thanks for the help. By the way, this GMC is still being used... old farm rig. We don't retire em.... we just use them then rebuild them and use them.....
1948 Dodge 2 ton 1950 GMC 1 1/2 ton 1952 GMC 3/4 ton
#33551 06/07/2002 8:46 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | The same water pump fits all GMC's from 1939-1959 including the 228, 248 ,270, and the 302. The only difference is in the pulley size. If you use a puller to save your old pulley you are in business..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#33552 06/07/2002 8:55 PM | Joined: Feb 2002 Posts: 61 Member | | Member Joined: Feb 2002 Posts: 61 | Originally posted by 53 4 me: The same water pump fits all GMC's from 1939-1959 including the 228, 248 ,270, and the 302. The only difference is in the pulley size. If you use a puller to save your old pulley you are in business.. Awsome... that's what I thought. I plan to use the old pully.
#33553 06/07/2002 9:31 PM | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | Stovebolt has them for $45. | | |
#33554 06/07/2002 9:51 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Guys the pulley doesn't 'Just pull off' I broches em they never fit again....I've no idea how my rebuilder does it but a puller ain't it | | |
#33555 06/08/2002 12:32 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | When I changed my water pump 5 years ago, the pulley was already on. I couldn't figure out if it was pressed on or not. My 350 series Jimmy has the 248 and the wide pulleys. I think it was about $65 and I had to turn in my old one for a core. The Filling Station has them as well........ I picked it up from Carquest right down the street..............
*** GMC ***
#33556 06/08/2002 1:06 AM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | I pulled mine off with a puller and pressed it back on.. Not a problem..
#33557 06/08/2002 1:11 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | I think it matters if you have a steel or iron pulley but press is better than puller | | |
#33558 06/08/2002 1:37 AM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | The GMC shop manual goes into detail about changing the pulley. Remember when pressing it back on to make sure you are pressing against the back of the impeller shaft and not against the pump body. You don't want to press the shaft through the bearing, you want to press the pulley on to the shaft.
