3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#33481 09/05/2003 2:50 AM
i got a 71 c-10....396 w a t350....finnaly got my 3.08 rear end in it....but now what do i need to do to get my speedometer to read right?a compensation gear?and if so where do i find this ?
#33482 09/05/2003 1:52 PM
First, check your speedometer to see how far it's off. Speedo check web page
Then remove the plastic speedo gear and take it to a tranny parts shop and tell them how much your speedo is off. They will sell you a new gear with the proper number of teeth to match. At the same time, replace the oil seals in the speedo gear housing. The gear should be under $10.
Fred
52 3600
69 C-10
