6 members (klhansen, Peggy M, Maybellene, TexasJim50, Hanks custodian, Woodcmiami), 92 guests, and 2 robots.
Topics128,059
Posts1,055,820
#334105 11/07/2007 3:53 AM
rex
Offline
Hey folks,
Quick Question. I am disassembleing a 216 and need to know if the dipstick tube is threaded or just pushed into the block. It does not immediately give but am afraid of crimping not knowing how it's installed.
Rex
rex #334121 11/07/2007 4:15 AM
It's pressed in. If you wnt/need to remve it, put a Phillips head screwsdriver (a #2 as I recall) in the tube, then grip with pliers/vice grips (the screwdriver prevents crushing). Then give it a twist and pull. It'll come right out. You can also drive it back inusing the same size screwdriver. Just lightly tap it back in. If it does gat damaged, 5/15" brake line makes an exellent replacement.
Bill Burmeister
LONGBOX55 #334156 11/07/2007 5:09 AM
rex
Offline
Bill,
Thanks, great tip with screwdriver. Will try.
Rex
LONGBOX55 #334251 11/07/2007 3:45 PM
Ex Hall Monitor
Ex Hall Monitor
Wow Bill, a 5/15th. Is that a whitworth size? grin wave
Tiny #334529 11/08/2007 1:32 AM
Ooops :hammering: I meant 5/16" grin
Bill Burmeister
