| | | Forums66 Topics128,059 Posts1,055,820 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 7 New Guy | | New Guy Joined: Oct 2007 Posts: 7 | Hey folks, Quick Question. I am disassembleing a 216 and need to know if the dipstick tube is threaded or just pushed into the block. It does not immediately give but am afraid of crimping not knowing how it's installed.
Thanks, Rex | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's pressed in. If you wnt/need to remve it, put a Phillips head screwsdriver (a #2 as I recall) in the tube, then grip with pliers/vice grips (the screwdriver prevents crushing). Then give it a twist and pull. It'll come right out. You can also drive it back inusing the same size screwdriver. Just lightly tap it back in. If it does gat damaged, 5/15" brake line makes an exellent replacement.
Bill Burmeister | | | | | Joined: Oct 2007 Posts: 7 New Guy | | New Guy Joined: Oct 2007 Posts: 7 | Bill,
Thanks, great tip with screwdriver. Will try.
Rex | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Wow Bill, a 5/15th. Is that a whitworth size?
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Ooops :hammering: I meant 5/16"
