| | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 86 'Bolter | | 'Bolter Joined: May 2005 Posts: 86 | I removed my leaf springs for overhaul, but can't remember which spring eye goes toward the front, or doesn't it matter? One eye has the spring only partially wrapped aroung the bushing tube.
Mike 1951 Chevy 1/2 ton w/ 1959 235 1971 Chevelle
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The one with only the bushing hole goe to the front, the double wrapped (military wrap) goes to the rear. There is a difference in the bushings, the rear is plain, the front is threaded internally.
Bill Burmeister | | |
