7 members (baldeagle, Hush, mick53, Southerntruck, SmalltownTRKGuy, Hotrod Lincoln, Gray_Ghost),
102
15
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33172 06/30/2004 2:03 PM | Joined: Feb 2000 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 69 | Does anyone know of a source for new differential bearings for '41-'58 1 1/2 ton Chevrolets (pinnion bearings, side bearings)? Can't find them locally. Thanks. ron | | |
#33173 06/30/2004 4:57 PM | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | If you can get a number from the cone and cup, any industrial bearing supply should be able to match them up for you. They're just standard tapered roller bearings, and should have an industrial application, as well as automotive. Post the numbers here, and I'll try to research a source, or email me. Jerry
#33175 07/01/2004 6:36 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | uncleb, Try www.bearingplace.com. They have a huge inventory and are very professional to deal with.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
