| | | Forums66 Topics128,186 Posts1,057,307 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 1 Moderated | | Moderated Joined: Sep 2007 Posts: 1 | I have recently acquired a 1939 Chevy 1.5 ton truck. I'm so tickled I can hardly stand myself  Are there any '39 chevy owners (or ANY Stovebolters)in the Western North Carolina area??? I'd love to get together with you and talk trucks. Tyler | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 39 and 40 share most body parts and mechanicals... a fer differences would be in the dash with the guages and knobs. other than that a 39 and 40 1.5 ton truck should be identical.
I have a 40 gmc 3/4 ton, and there are several other members here who have pre-war trucks here. As most of the trucks of the era share drivelines and mechanicals you can learn a lot from members with trucks in the year range of 37-46. Not all parts interchange, but to give you an example... 37-39 share the same dash and guages. 39- 46 share the same doors and windshields. 39 and 40 have nearly identical cabs, while the 41-46 trucks had a cab that grew 2 inches in length. | | | | | Joined: Aug 2005 Posts: 278 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 278 | I also read that the 41-46 cabs were bigger then the 39-40 cabs. I have a 39 and used 41-46 doors, fuel tank and floor panels. Just curious as to where in the 41-46 cabs they put those additional 2 inches? Any idea?
| | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | The cowl was moved about 1 5/8 inches forward to increase leg room. | | |
