7 members (Oswald, FAST55, Ponchogl, 2-Ton, Oldcaliforniakid, Hotrod Lincoln, Donf), 74 guests, and 2 robots.
Topics128,042
Posts1,055,519
Members48,424
#331074 10/31/2007 4:28 PM
Apprentice
Apprentice
HI I have a 1948 chevrolet 1 ton truck and need to know if .923 is the proper size for a standart king pin reamer and where do you find one or who does king pin work in my area
Ex Hall Monitor
Ex Hall Monitor
Yer profile doesn't say where "my area" is (I assume VA means Virgina but that covers a lot of area) so my best advise is to check the yellow pages for a spring & axle company. Many front end shops will do kingpins in rural areas where there are a lot of old farm trucks.
Tiny #331239 10/31/2007 11:21 PM
A NAPA machine shop can usually do it, they often hone the bushings on the same machine they use to hone connecting rod bushings. I prefer honed instead of reamed king pin bushings.
Either way, reamed or honed they should be just the right fit, and the two holes must line up exactly. It's a bad idea to try to ream them separately without considering alignment between the two bushings.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
