| | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 7 New Guy | | New Guy Joined: Oct 2007 Posts: 7 | Hello,
New to sight. Have read from this site for days and have learned an enormous amount. I have been given a '51 CHEVY 1/2 Ton from my grandfather.(I have been waiting on this since I was a kid, he is 90 and I am 52) I have worked on vehicles for years but nothing major. The body is perfect but I have decided to rebuild the 216. Engine and transmission removal went smooth but I have my first need for help. I'm to pulling the clutch and thought this would be simple but from reading from other posts I see that the bellhousing cannot be removed to allow better access to clutch cover. Looks like cover has 6 bolts and I cannot get a wrench on the top 2 after I removed the plate from top of bellhousing. Can someone who has experienced this give advise on what tool would be used?
Thanks, and I look forward to talking to you guys. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | rex,
Welcome to the new "Bolt". If you turn the engine over using the flywheel and a screwdriver, the 'top' bolts will become the 'bottom' bolts, and will be easy to access. Was this the question?
Stuart | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Just did this myself last night on my 216.Do as Stuart says. Not too hard really. Just back them out slowly and alternate because of clutch spring pressure.Now I'm dealing with the flywheel which is a little harder to to do because of bolt torque specs,locking tabs and trying to keep the flywheel from turning. Looks like I have to purchase a flywheel wrench that grabs the ring gear.
Drew
| | | | | Joined: Oct 2007 Posts: 7 New Guy | | New Guy Joined: Oct 2007 Posts: 7 | Stuart,
They say there are no stupid questions but after getting your reply I think this one came pretty close. It's the advise that I needed. Feel silly that I did not think of it myself.
Thanks, for your patience
Rex | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Stuart,
I had been asking the same question for my 1958 235 engine, however I guess I didnot follow when you said "turn the engine over using the flywheel and a screwdriver", what does that really mean. My bell housing is just one peice of it and everyone says remove the flywheel first before I take the bell housing. Please throw some light.
Thanks Ganesh | | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Ganesh, Two (I think) of the bolts that hold the bell housing to the engine are behind the flywheel. You have to remove the flywheel to access those bolts.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Ganesh,
REX is trying to remove the pressure plate, or as he refers to it, the clutch cover. Instead of trying to reach up into the bellhousing to get to these six bolts, it's a simple matter to rotate the flywheel and brings the bolts into easy reach.
You can do this with a bar, a screwdriver or a flywheel 'turner'...any means to roll those bolts down to the bottom.
The clutch, pressure plate and flywheel must be removed to gain access to the upper bolts that hold the bellhousing to the block. Jeff has already mentioned this above. Does this make it more clear to you.
Stuart
| | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Ok I have to figure out how to remove the flywheel, but still curious on what Stuart said
Ganesh | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Yes sir, now I get it, thanks Stuart appreciated | | |
