| | | Forums66 Topics128,014 Posts1,055,330 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 | Can someone refresh my memory on settings for balanced welding? (gauge settings) Oxy/acc
Ridge dweller
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | ridgeview,
I have always used 6 lb of acetylene and 25 lb of oxygen for my every day settings. In actuality, the settings are dependent on tip size, but the ones I mentioned work for most welding tips and most cutting tips.
If you are running a rosebud or a #3 cutting tip, the settings must be cranked up...obviously.
My guess is that if you 'googled' this subject you would find more info than you needed. Good luck.
Stuart | | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 |
Ridge dweller
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ridge, give this a try. I'll use a victor #2 tip for an example. Open your valves on the torch all the way now adjust your acetylene regulator till you get some gas flow and light the torch. Now keep increasing your regulated gas till the flame leaves the tip. This will probably be some where around 3 or 4 psi. That is the absolute max pressure that the #2 tip can handle. For any condition now 2 to 3 psi will supply enough acetylene. Now with your acetylene flame lit and at its max opening (with out it leaving the tip) adjust your oxygen regulator till you have a neutral flame. For this #2 tip this will probably be around 4 or 5 psi. So this is the maximum oxygen pressure that you will need for the maximum acetylene that the #2 tip can handle. You can use this procedure to determine the range of pressures for any welding, cutting or heating tip. Keep a chart and you will know for sure exactly where to set your gauges. Stu’s reply is also valid as most welders just use a higher setting to cover most of their needs. As a general rule I personally wouldn’t run my oxygen regulator much above 8 or 10 psi and the acetylene at 4 to 5 psi unless like Stu said, you were heating or burning with a very large tip. Also if you’re new to gas welding remember, 1/4 TURN on the Acetylene and FULL open on the Oxygen. This is in case you have a hose/torch/regulator fire you can kill the Acetylene quick and the oxygen being high pressure has a double seat and can leak past the packing nut unless you fully seat it open. Have fun and stay safe. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | It's always a good idea to have check valves on the torch handles to prevent backflow of the flame up the hoses and gauges. Backflow can occur when shutting off the torch.
34 & 35 trucks are the greatest
| | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 | Thanks for the good advice men.
Ridge dweller
