| | | Forums66 Topics128,168 Posts1,057,027 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 14 New Guy | | New Guy Joined: May 2003 Posts: 14 | Been lurking forever.........Just bought a '65 C10 LB with what I am told is a 292 bolted to a 4 speed manual tranny. The truck had poor tires so I just drove it around the farmyard. Not positive on the 292 as I couldn't make out any casting #'s, but it runs like a top so it was not a major concern. Big Question - What is the likely rear-end in this truck? I know - I know - I have been searching the archives but can't find what the options were for this truck. As I am going to daily drive / restore her - what can I expect to be the highway speed - am I going to get run over at 55? The Fun Begins..........
Brian 1955 (2nd) Chevrolet 3200 1999 Suburban (family truckster) 1966 Ford F100 (parts runner) | | | | | Joined: May 2003 Posts: 14 New Guy | | New Guy Joined: May 2003 Posts: 14 | By the way, I haven't picked up the truck yet.......be late next week.
Brian 1955 (2nd) Chevrolet 3200 1999 Suburban (family truckster) 1966 Ford F100 (parts runner) | | | | | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | Easy way to check if it's a 292.. the motor mounts are offset, that is not even on both sides of the block. One side is farther back than the other, I think it's the passenger side that's back farther. Sorry can't help you on the rear-end... except suggest you lift the back tires off and count the rotation of the driveshaft compared to the wheels.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
| | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | IIRC, '65 half tons came with a 3.73, with a 4.11 and a 3.07 optional, and the 4.11 and 3.73 could also be had as positraction units.
1st gear in your tranny is granny gear and 4th is direct drive (1:1). My truck has a 3 speed and a 3.73 rear in it. It does 55 easy and can maintain 65 on the interstate although it gets rather loud in the cab from the 250 roaring. Any faster than that and you're beginning to push the engine. | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | With a 4.10 and 235/85x16 tires(31" tread height) I could run at 60mph all day without straining my engine, but I like 50 - 55 better. The Acuras can go around me; I remember the parable of the hare and the tortoise. On the road I use 2 - 3 - 4, and save first gear for when I'm crawling up a boat ramp or something, to keep from slipping the clutch. If I wanted to run faster I'd get a transmission with an overdrive. 1951 3800 Be the change you want to see. -hotshoe
