5 members (Gib70, moparguy, Hotrod Lincoln, artinva, Bill Hanlon), 80 guests, and 2 robots.
Topics128,078
Posts1,055,935
Members48,430
#33036 05/03/2002 2:10 PM
I
I Offline
On the 42, the starter has quit making contact. If I put a spacer down on the button on the starter it will crank. I don't see any adjustments. looks like I need to make and adjustable rod right at the starter.
Junior Member
Junior Member
IWL BCNU,
On my 40 there was a way to adjust the contact plate on the starter. My truck has been running on 12 volts for over 30 years and I've had to do this several times to keep it working. The switch only slides a fraction of an inch but that should be enough to work. You also might try replacing the switch, as they do wearout from the arching when starting the truck.
Good luck.
I do believe you can get a new switch (that attaches to the top of the starter) at NAPA or local parts store.If they look, they can find it and order it.
.Some places even have it in stock!
OK , so you want to do it on the cheap ? just epoxy a couple of thick washers onto the button on the starter switch . grin
Rotate the contacts in the switch 180 degrees . They are wedge shaped and get worn on one side from use. By turning them around 180 degrees you have a brand new side to wear out yet. East to do and you already have the parts, (if someone hasn't alrady done it) so the cheapest too.
37 Chevy 1/2 Ton
86 Chevy Blazer
98 Drudge 24 valve Cummins
One worn out Timberjack
