| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33025 02/05/2002 10:05 PM | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | 292 inline 6 going into a '53 chevy 3/4 ton stock front end. What is the best bet for motor mounts? Can I use the Stovebolt smallblock mounts? Other ideas. Any advise would be appreciated Anybody out there running a 292 or 250 ??? what did you use for mounts?? [email protected]jl
'53 chevy 3/4 ton
#33026 02/05/2002 10:38 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | The 292 takes small block mounts but the mounting bosses on the block are offset so the usual kit type V-8 mounts on a bar won't work without some reworking.I you can weld it should be easy enough. make sure you have the engine located properly in the chassis to suit your situation | | |
#33027 02/09/2002 12:19 AM | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | just put a 250 in my 54chevy 1/2 ton and I ordered the mounts from Tom over at stovebolt-slides in the frame rails (either weld them of drill hole and bolt) works great. Measure and re measure just to be safe and the measure again. I have a 292ci that I wanted to put in but decided to use the 250. the mounts for the 250 and 292 are different. the left side of both engines is offset and the left side engine mount holes are also alittle different ...spacing of bolt holes. Tom has both sets 250 or 292 just tell him what you want Good luck.
marlo | | |
#33028 02/09/2002 12:21 AM | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | almost forgot the important thing....RADIATOR CLEARANCE. you might have to do a little modification but measure and test fit and you should be ok. THe 292 is alittle longer than the 250 and 235. marlo | | |
#33029 02/09/2002 5:50 AM | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | yup on the radiator comment! Did you end up using the stock fan or an electric pusher fan?????
I will give Tom a call at stovebolt. Sounds like just what I need
'53 chevy 3/4 ton
#33030 02/09/2002 5:51 AM | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | yup on the radiator comment! Did you end up using the stock fan or an electric pusher fan?????
'53 chevy 3/4 ton
#33031 02/11/2002 2:05 AM | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | I used a pusher/puller fan and I did not run the fan on the water pump. I thought it looked better and the electric fan w/relay (very important) works very well and keeps my girl very cool. 292 are great engines lots of torque and they dress up very nice. later good luck on the project. | | |
