1 members (Jimmie D), 110 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#3282 12/21/2004 2:15 AM
I have a 40 pick-up with a 235 from a '52 powerglide car that I am trying to put air conditioning in. The new motor has wide pulleys for 3/4 inch belts and I need to change to the narrow pulleys. Does anyone know what year car or truck that has a narrow crankshaft pulley that will fit my '52 235. Dale
#3283 12/21/2004 2:24 AM
1953 and later pass use a 3/8" belt pulley.
1953-54 has a 6" diameter pulley and should be used with the high mount water pump.
1955-62 has a 6.750" diameter pulley.
My Blog
#3284 12/21/2004 3:10 AM
So you are saying that only '53 & '54 passenger cars have the correct pulley for my application.
Is there another solution. Dale
#3285 12/21/2004 5:37 PM
1955-62 truck balancers used a 1/2" belt. If you use one of these with a 3/8" belt the belt will run deeper in the groove and the belt will be running at about the right diameter. The pulley groove is plenty deep.
My Blog
