4 members (Otto Skorzeny, J Lucas, TexasA&M48Truck, Ed Atkisson), 86 guests, and 6 robots.
Topics128,021
Posts1,055,373
Members48,420
#32834 05/08/2004 6:02 PM
My Rochester Monojet carb squeals loudly out its throat when idling. If I give it a little gas the squeal goes away. I first thought it was the generator bearings going out.
Is this normal? I have one of those small after-market air cleaners on it. Will a better air cleaner muffle the sound?
Thanks.
#32835 05/08/2004 9:24 PM
Most likely the squealing sound is an indication of a vacuum leak on or around the carb.
#32836 05/09/2004 12:22 AM
Afu45 is probably on the right track. Spray some W/D40 around the carb connections and especially around the base. If you have a leak, the engine should pick-up a few rpms and the noise should stop momentarily.
Truck Tinker
#32837 05/10/2004 12:34 AM
I had one of those carbs on a 74 Nova with a 250. I found that if I played with the mixture screw I could get it to squeal. No vacuum leak. I had that car for 10 years, and when ever I messed with the carb I could get it to squeal or whistle by playing with the mixture.
I have heard one or two other carbs do the same thing, I assume it has to do with air passing over/around/thru passages in the carb throat.
#32838 05/10/2004 2:00 AM
Anonymous
Unregistered
Anonymous
Unregistered
The monojet squeals when you set the idle to low.
Boo
