5 members (MikeStone1953, Bill Hanlon, Wally / Montana, Oswald, tesa), 162 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
I looking for a way to replace the drivers window rear channel.
Mine is missing.
I see that the channel is spot welded at the top and bolted at the bottom.
ANY SUGGESTIONS
THANKS
TIGHT IS TIGHT,TOO TIGHT IS BUSTED
Apprentice
Apprentice
Bill,I believe the rear channel has a small screw at the top which may be rusted off and hard to see.This channel has to be removable in order to remove the door latch.The front channel is spot welded at the top and bottom. Chip
Thanks Chip.
You are correct!!
I looked in the repair manual under latch removal and it stated the the channel had to be removed to get the latch out.
Thaks again for the info
