3 members (WICruiser, Phak1, 1 invisible),
40
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,009 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 33 New Guy | | New Guy Joined: Nov 2006 Posts: 33 | I looking for a way to replace the drivers window rear channel. Mine is missing. I see that the channel is spot welded at the top and bolted at the bottom. ANY SUGGESTIONS THANKS
TIGHT IS TIGHT,TOO TIGHT IS BUSTED
| | | | | Joined: Oct 2006 Posts: 31 Apprentice | | Apprentice Joined: Oct 2006 Posts: 31 | Bill,I believe the rear channel has a small screw at the top which may be rusted off and hard to see.This channel has to be removable in order to remove the door latch.The front channel is spot welded at the top and bottom. Chip | | | | | Joined: Nov 2006 Posts: 33 New Guy | | New Guy Joined: Nov 2006 Posts: 33 | Thanks Chip. You are correct!! I looked in the repair manual under latch removal and it stated the the channel had to be removed to get the latch out.
Thaks again for the info
