| | | Forums66 Topics128,043 Posts1,055,609 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I have been trying for a couple of years to get the doors to close properly on my 1955 2nd series.I have installed new latches and have the drivers door operating OK,but the pass.side is driving me nuts.I would like to have a set of Bear Claw latches installed,but I cant find anyone around here to do the job.I hate to buy a MIG welder just to do the job.Does anyone know of a better latch system for the 55 2nd that doe not require cutting and welding? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Sounds like a great excuse to buy a MIG. I installed some on my 54 and it was not that hard to do. You may be able to rent a wire feed welder from Home Depot if one is in your area. | | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | Have you checked the condition of your hinges? I had a similar problem with my doors. I finally took the time to take the doors off (left the hinges bolted to the pillars). I found 3 hinges with broken pins. On the 4th hinge (top passenger) the pin had worked its way halfway out of the hinge. After I fixed the hinges (PITA by the way), my doors closed a WHOLE lot better. P.S. By all means, use this as an excuse to get a mig welder!! You will love it.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Hinges are AOK,its just a PITA trying to adjust the latches.I realize the TF doors are very heavy,but the pass.side is driving me nuts. | | | | | Joined: Oct 2006 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 111 | also check lower door hinge pocket. this is were the hinge bolts to door. there are three nut plates welded a sheet metal bracket. this bracket can rust out, untill this is repaired the door will always sag. | | |
