I've been going over my left side door and found that it hangs down on the handle side. I checked the hinge pins and although one is slighly bent, I have ordered new ones, I found that there is a piece on the door that looks broken as well as worn. Looks to slide the door up as it closes. It is also welded or riveted to the door. Is there a replacement part for it? How else would I repair it?
Matt
\'47 GMC 1 1/2 ton, "Bertha"
1942 Chevy 2-Ton Truck, "Helga"
There is a fine line between "hobby" and "mental illness."
