9 members (48jim1ton, Gdads51, Forty9, Hotrod Lincoln, gswbbc, frogfarmer, Wayne67vert, sron48, dt235sd),
75
0
Mod | | | Forums66 Topics128,043 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | Very close to getting my body back fron the body and paint guy. I have this fear that although my doors will look perfect when mounted in the jambs on the chassis, I'll get it home install the rubber and have mis-alignment. Unfounded fear or a real concern? Should I have the body man do the rubber install BEFORE it leaves the shop? Thanks :confused: | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Rubber changed mine by quite a lot. If he'll do it and you can afford it, go for it. They do charge by the hour? If he doesn't want to touch it, at least you know he has experience with them. | | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | Appreciate the comment Chuck. It is what I would expect. Since I am paying (and paying huge) for a restoration, alignment would,should I would think, include the doors. Not just metal to metal, but as they would ultimately be - w/ seals. Would you think that the hood would be also effected by new seals? Thank, -jeff | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I was really lucky with my hood - 20 minutes to done. I did it with the seal and hood bumpers in place. The hood seal will affect the fit, but not to the degree that door seals have on the doors. | | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | Thanks Chuck, Coordinating the hood would be tough. I had a difficult time just getting it off. Worrying about the new paint would be too much. -jeff | | |
