7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible),
125
Mod | | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | Now I've got a couple of questions I'm not sure about. On the lower window wipe seals, the ones that fit in the channel at the lower edge of the window. Are they suppose extend all the way to both edges or stop at the end of the channels? If they extend what holds them in place? I might be missing something because there is nothing beyond the end of the channels to hold them or seal that section of the windows. Now on the door weatherstrips. I know there is one for around the door and one for the bottom but I keep seeing parts listings for in the channel around the door frame and I have no such channel. Do I need one strip per door or do I need a inner and outer( 2 per door). I haven't yet been able to find a orginal break down for them that shows me what I need so I'm kinda lost and confused on this. Thanks
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | The channel around the door openings may pertain only to the AD series trucks. Your 46 should be a Art Deco model correct? | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | The channel around the door frame is for the windlace. I'm not sure what you're asking re: the lower window wipe seals ... but maybe THIS will help?
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the window lower wiper seal doesn't really do much for "sealing" and just fit the length of the channel - they're actually the "lower glass setting tape" and just help fill the space between the glass and the window opening when the window is up to lessen drafts and keep the glass from rattleing the door seals on the 46 are the kind that fit under the panels surrounding the door opening - as Alan sez, called \'windlace\' - to prevent the wind whistleing in yer ears - the ones that fit in 'channels' are the AD years Bill | | |
