| | | Forums66 Topics128,148 Posts1,056,811 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | Is there any sources for this item Also see link: http://mars.ark.com/~babytrkr/accman/987187-164.html I was thinking about using my old brake pedal pad and carving one out of it if there are not any reproduction of this item Appreciate any comments Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no source .... do you have the inside mirror? if so the grommet is not used [it fills the notch in the case that's for the mirror mount] ... if not, get one!  otherwise I'd expect to find something close enough to adapt at a local auto parts that has a selection of grommets/plugs/etc Bill | | | | | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | Ah!!! Do I feel silly now Its been a hot summer here and I was looking at how to install the junction fuse block and notice that rubber piece was missing on the bottom of my speaker cover. Yes I do have a rear view mirror  | | |
