4 members (54farmtruck, Danielbolt, Wooley, 1 invisible), 110 guests, and 0 robots.
Topics128,157
Posts1,056,875
Members48,456
What solder type ws use on these old radios?
1955-1959
Focus,
My wild guess would be a tin/lead rosin flux solder...maybe 60% tin and 40% lead. There is a radio forum that would be the place for a 'for sure' response.
Stuart
It definitely was NOT acid core solder.
Just look for electronic solder. It does not have acid flux but uses a rosin core. The brand that I remember as being prominent is Kester.
1951 1 Ton Completed
Yes, 60/40 electronics solder is what should be used.
Don't be tempted to try the new lead free solder on old components, it has a higher melting point and can destroy the terminal strips.
Paint & Body Shop moderator
Thanks, All
I Replaced the paper caps using 60/40 resin solder and also replaced the rectifier tube (OZ4)
Powered it up yesterday and listened to a baseball game on it in my den.
Focus,
thanks for your success story. We like to hear them. Not only is it worth the effort but it really makes your day when it comes alive, right?
Moderated by  truckernix
