8 members (Bill Hanlon, Waveski, Jon G, Pre '68 Dave, 3B, kades51, 2 invisible),
126
Mod | | | Forums66 Topics128,283 Posts1,058,513 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I see vibrator tubes listed in the parts book. Just for sheer curiosity, what does a vibrator do in one of these old radios.
Stuart | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | Atomarc, the circuits used in these old tube radios use a variety of Dc voltages, some as high as 270 V. In order to supply these voltages, a power transformer is used, that runs on Ac, and steps up the Ac voltage from 6 volts, to somewhere around 300 v. This Ac voltage is created by the vibrator, which alternately applies 6v to two opposite windings in the transformer primary. It does this using two sets of points, a magnetic coil and a moving armature, much like the one in a door buzzer.
The higher secondary Ac voltage from the power transformer is applied to a rectifier circuit to create the high voltage Dc supply. The OZ4 tube is used in this circuit.
Fred | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | truckernix,
Thanks for the excellent explanation. It sounds like this might have been some of the incentive to develop transistors.
Stuart | | |
