Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (kades51, DaveV), 151 guests, and 5 robots.
Topics128,283
Posts1,058,513
Members48,490
#326705 07/27/2006 10:34 PM
I see vibrator tubes listed in the parts book. Just for sheer curiosity, what does a vibrator do in one of these old radios.
Stuart
#326706 07/28/2006 12:04 AM
Atomarc,
the circuits used in these old tube radios use a variety of Dc voltages, some as high as 270 V. In order to supply these voltages, a power transformer is used, that runs on Ac, and steps up the Ac voltage from 6 volts, to somewhere around 300 v. This Ac voltage is created by the vibrator, which alternately applies 6v to two opposite windings in the transformer primary. It does this using two sets of points, a magnetic coil and a moving armature, much like the one in a door buzzer.
The higher secondary Ac voltage from the power transformer is applied to a rectifier circuit to create the high voltage Dc supply. The OZ4 tube is used in this circuit.
Fred
1951 1 Ton Completed
#326707 07/28/2006 2:43 AM
truckernix,
Thanks for the excellent explanation. It sounds like this might have been some of the incentive to develop transistors.
Stuart
Moderated by  truckernix
