| | | Forums66 Topics128,088 Posts1,056,122 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I just broke the On/Off Volume Knob function in my '49 Burb. It's an original box & controls with an AM-FM conversion board. The knob/shaft turn but the radio doesn't go on and there in no detent for the On/Off function. Anyone know how and if this can be fixed? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | steveg, of all the components on the original radio, a broken volume control is the hardest to deal with. This is because the design using a switch for tone control was not very common. Most of the radios at the time used a continuous control.
In your case it depends how the conversion unit used the original control. It would probably be best to take it to someone who does the conversions on a regular basis. | | |
