1 members (RLB), 215 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#326509 01/15/2006 3:05 AM
the previous PO welded metal over the radio cutout (why someone would do that escapes me) so i can't put a decent radio in my 53 gmc 1/2 ton. so, i put a new am/fm/cd in the glove box with a 6-12v converter. i did use an original type mast antenna though. one of them spring loaded type antennas that were popular decades ago. anyway, the AM band works fine, lot of stations, but only static on FM. tried raising it and lowering it, but not even a hint of sound. could it be an antenna that isn't the right wavelength for FM. long shot, but just wondering if anyone had any ideas before I chuck this on and get another.
tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#326510 01/15/2006 3:59 AM
yes, likely the antenna is NG for FM - might think about the 'hidden' style antennas some of the suppliers have - they're made for both AM and FM, can be mounted under the running board - the one at Amer Clas sez 12V - also keeps folks from noticing that you have any audio equipt in the vehicle
#326511 01/15/2006 5:07 PM
You can adjust the antenna to 31" which should be optimum for FM. There might still be something wrong with the antenna but perhaps the radio is bad? Can you bench test it and get it to work? Just a short piece of stiff wire stuffed in the antenna jack should get some FM stations if there are any around you.
-Ed
Ed Fallon
In seemlingily endless process of restoring a stock 1953 chev 3100 pickup.
#326512 01/16/2006 7:13 AM
that's kinda what i thought ed. i couldn't imagine an antenna that wouldn't get fm too. i'll try the 31 inches. i did'nt figure out the lambda value of the mid range of the fm frequency band to see what length it should be.
thanks bill, i'll check into that hidden antenna. sounds interesting but i got 6v so that'd be another thing to run off the converter.
tony
#326513 01/16/2006 11:45 PM
That's odd. My old '65 Mustang had an AM antenna with the extendable segments, and it worked just find for FM.
1954 GMC De Luxe COE
#326514 01/17/2006 8:06 PM
It's highly unlikely that the antenna is the problem. If the FM portion of the radio was working, you would get at least some FM stations. The FM & AM sections of the radio share some common circuitry, however, they use different methods for demodulating the signal. Therefore there are usually specfic circuits dedicated to each function. It appears as if the FM demodulator or some FM specfic circuit is not working.
Moderated by  truckernix
