2 members (KEVINSKI, Dennys28),
96
0
Mod | | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 19 New Guy | | New Guy Joined: Dec 2006 Posts: 19 | My bed was in pretty bad shape and after a few years of ply on top finally rotted out enough to drop my scooter onto the frame one day. I was planning on ordering a kit and in the mean time popped a steel 76 bed on. The oak and pines just don't appeal to me so I'm looking for something different, I did find a nice site that has the pattern for the pieces. It's at GMC Pauls http://www.gmcpauls.com/47-72_BedWood_Info.htm
My other truck is a Ducati
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | If you go to my site at the bottom you can see the cherry wood and purpleheart wood that I used for the bed of my 53. You can do it if you have some woodworking tools. Much cheaper than the kits. Also you can have a choice of many different hardwoods. | | | | | Joined: Dec 2006 Posts: 19 New Guy | | New Guy Joined: Dec 2006 Posts: 19 | I've setup my router bench to do the strip seat gooves in a single pass. I'll be starting as soon as I get my wood or grass in my case. I decided that since I call her teagreen I'll be using bamboo as my bed wood. A local lumber yard has a source for cultured strand which is supposed to be the hardest bamboo board. Fingers crossed.
| | | | | Joined: Aug 2005 Posts: 25 New Guy | | New Guy Joined: Aug 2005 Posts: 25 | I am thinking of removing the metal floor on my 1969 Chev longhorn and replace it with wood. Can you tell me how wide the wood needs to be, how thick and if the wood fit into each other or if there is a gap that the metal strips cover?
Waggy Chev- Sedan 36,Apache 59,Longhorn 69, Chrysler 300 - 1970 conv, Ford Prefect 49, International L130 1950 Surrey, BC, Canada
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Hi Waggy - nice to see someone from Surrey on the board. I did my own bedwood in my '40. Pretty straightforward job, although a bi time consuming. Not sure how your bed details compare to mine but you are welcome to have a look | | |
