2 members (Jay R, Donf),
71
Mod | | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 31 Member | | Member Joined: Oct 2005 Posts: 31 | Preparing to mount new bed on my 1938 HC. I ordered bed mounting blocks from a reputable vendor. I set the blocks on the frame, and it appears to me that the rear blocks are not tall enough. I seems to me that they should be as tall as the combined height of the cross sill and its block. Does anyone know offhand what this height should be?? TNX | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I have the same issue with my 40. Blocks I ordered are 3 1/2" high - I need something like 4 1/4 to come up tight to underside of bed boards? | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | We make those blocks 4-1/8" tall, for both series. The blocks are different, but the height is the same for both 37-39 and 40-46. If that is incorrect, I would like to know about it. The top of the rear blocks should be even with the tops of the cross sills when everything is installed, including wood blocks under the cross sills.
Mar-Ktech | | | | | Joined: Oct 2005 Posts: 31 Member | | Member Joined: Oct 2005 Posts: 31 | Thanks for the response. I will be ordering blocks from you today. After messing with these old'bolts long enough, you begin to find who the real pros are. TNX | | |
