| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 23 | I hope that someone can reply back to me with this simple question? I have tried to locate this answer on this site...and my questions are more simple than I can find answers.
What is the proper assembly order?
Option 1: Install bed sides, cross member supports first....and then install the wood after the metal is installed?
Option 2: Install the wood on the frame and install the bed metal around the wood.
Option 3: Assemble the metal and wood separately off the truck and put it all on the truck at once?
Does anyone have a good step by step guide? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd recommend putting the whole metal box together w/ cross sills, set it on the truck, install the wood, bolt it down - really need everything square and secure before the wood goes in, but too heavy for lifting once it's all together
Bill | | |
