| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Mar-K's directions for installing bed hardware call for a 1 9/16" Forstner bit to drill the holes for the mounting offset washers. I can't locate such an item around here. Sears, Lowes, Home Depot all carry 1 1/2" bits and 1 5/8" bits, but no 1 9/16" bits.
Will a 1 1/2" bit do the job? | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | Tom: I measured our offset washers to be right at 1-1/2" diameter. That 1-1/2 bit leaves no room for the build-up of finish material on your boards, and any finish except penetrating oil will have some build-up. We would suggest using the 1-5/8 bit instead. That leaves 1/16 all around the washer and should look OK. Much safer than risking damage to the finish by the washer. We bought the 1-9/16 forstner bit at woodworker supply http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=803-653. Good luck on your project Mar-Ktech | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | WOW, right from the horses mouth! Is this fantastic customer service...or what!
Impressed-Stuart | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I ordered a 1 9/16" Forstner bit on line today. I had hoped to make the holes today, but I guess I'll have to wait.
It's a good thing I have to wait, though, because when we put the bed on the frame, NOTHING lines up. The whole thing is cocked, and if I had made the recesses for the washers, I'd be in real trouble.
I guess I'll pose another question about squaring the bed.....
Thanks, Mar-Ktech | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Hey Tom, Will you loan me your bit when you are done? | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Sure thing, Houston. But it might cost more in postage than it's worth. I ordered mine from MLCSwoodworking.com today for $10.95, shipping included.
If you still want it when I'm done, though, let me know and I'd be happy to send it to you. :p | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | If you don't have a drill press (which I don't) I found it useful to drill in a little bit and then drop the washer in and feel around the edges to see if the depth was the same. Then I knew which way to tilt the drill to square it up. I drilled until 2 washers would sit in the hole and be flush with the surface. Also I noted that the Mar-K tech tip said to put the counterbores towards the front of the truck. In my truck (52)this orientation would result in the washer touching the bedstrip and the counterbore touching the groove in the wood. The back 4 counterbores should be towards the outside and the front 2 towards the inside on a 1/2 ton A.D. truck. Thier drilling tech tip is not application specific so you need to watch what you're doing. Good luck.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Luckily, I have a drill press. I can do a lot of damage with it, too. | | |
