| | | Forums66 Topics128,018 Posts1,055,340 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | Where do the offset drilled blocks go as opposed to the center drilled blocks. I know that one set goes at front sill, and the others at the rear center sill, but which one uses the offset blocks and why? Thanks in advance.
P.S. as I get ready to return my front bed panel to a respected vender I am cursing myself for not ordering from MarK. I ordered it during a sale and I was getting other parts from the vender. The mounting holes on the one I got were drilled about an 1/2" off and it was dented. The bed parts I have gotten from MarK are perfect and of high quality. Just my .02 | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | My Mar-k parts arrived packed in foam and heavy duty cardboard, excellent packing, nice looking quality, plus made in the USA.. Mike | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | Originally posted by Nifty 50 2: Where do the offset drilled blocks go as opposed to the center drilled blocks. I know that one set goes at front sill, and the others at the rear center sill, but which one uses the offset blocks and why? Thanks in advance.
Nifty: The bed block with the off-set hole goes under the cross sill that is just forward from the rear sill. That frame hole is quite close to the edge of the frame and the block offset helps center the load on the frame rail, even though the bolt is not centered. http://www.mar-k.com/bed_mounting_information.pdf for a brief description of mounting instructions. Mar-Ktech | | |
