6 members (Gray_Ghost, VEW, FAST55, 50Chevy3100, J Lucas, 1 invisible), 70 guests, and 0 robots.
Topics128,075
Posts1,055,918
Members48,429
#325227 05/06/2006 8:57 PM
Where do the two center cross sills go on the frame of a 1951 1/2 ton
#325228 05/08/2006 3:21 AM
One goes just before the frame kick up. It only bolts to the bed wood. It clears the frame by about a half inch and comes in contact with the frame only when a heavy load is put on it. Its location can usually be determined by locating a worn place on each frame rail just in front of the frame kick up, this is where the cross sill came in contact with the frame during a heavy load.
The other cross sill installs just behind the frame kick up using a 2 inch wooden block. Its mounting hole should be the first hole just behind the frame kick up.
hope this helps
#325229 05/08/2006 8:37 PM
High school hauler Thanks for the info,That is just what I was looking for.
#325230 05/08/2006 11:45 PM
Yeah, thanks! I'm just putting wood back in mine, but the mysterious 3rd support was never there to begin with.
