1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31972 03/20/2004 11:25 PM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | I have a GMC with a 228 and I would like to replace the oil pan gasket . I did a search on the NAPA site and they seem to have one so I assume the local NAPA will also. Anybody use this gasket set from NAPA? What did you think? | | |
#31973 03/21/2004 1:02 AM | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | I got a felpro one piece gasket for my 350.. cost's $25.00 but supposed to cure the leaks.... I havent installed it yet because the rear main is leaking too.. and I'll need to be replacing it soon..
#31974 04/04/2004 5:00 AM | Joined: Jul 2003 Posts: 38 Apprentice | | Apprentice Joined: Jul 2003 Posts: 38 | Thomas, I have a 39 GMC with a 228 and used a fell-pro gasket set. Its the same as the orginal and I had no leaks. I have not seen a one piece gasket, but it would be easier to install. NAPA sells good quality parts so I think it will do fine. By now you may have already installed the set, since you posted your question 14 days ago. Time passed me by, must have been sleeping at the wheel.
Jim
Jim
#31975 04/04/2004 5:01 AM | Joined: Jul 2003 Posts: 38 Apprentice | | Apprentice Joined: Jul 2003 Posts: 38 | Thomas, I have a 39 GMC with a 228 and used a fell-pro gasket set. Its the same as the orginal and I had no leaks. I have not seen a one piece gasket, but it would be easier to install. NAPA sells good quality parts so I think it will do fine. By now you may have already installed the set, since you posted your question 14 days ago. Time passed me by, must have been sleeping at the wheel.
Jim
Jim
