1 members (baldeagle), 87 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#31647 02/21/2003 4:39 AM
Will a distributor from a 216 chevy fit on a 261?
41 Chev 2dr coupe
51 3100 w/a 261
11 Camaro RS ragtop
#31648 02/21/2003 5:54 AM
It probably will but why? the 216 points and distributor cap are harder to find in the parts stores, atleast try to find one from a 235 you can get parts at most parts stores
#31649 02/21/2003 6:46 AM
The composition of the drive gear is differant because the cam composition is differant, and they need to match. Also, the 261 has a differant set of weights and springs. The breaker plates are completely interchangable- I put a dual point conversion kit for a 216 dist. in a 261 dist and it fit right in.
Paint & Body Shop moderator
