3 members (46 Texaco, wilbur53, 1 invisible),
69
Mod | | | Forums66 Topics128,264 Posts1,058,357 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31335 11/10/2001 9:54 AM | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | Ok guys...I know I've got a '54 GMC sitting out there in the driveway, sucking $$ out of my wallet, however, I am not sure if it's a 1/2, 3/4 or 1 ton and what size engine it has for sure, (I think it's a 235). It is a long bed, (89 inch bed wood I believe and the thing that makes me think it might be a 3/4 or 1 ton is the fact that the rear leaf springs are huge...a real thick stack with a helper spring below that. Opinions? Thanks!  | | |
#31336 11/10/2001 11:07 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Have you any pictures?
[ 11-10-2001: Message edited by: Mechainiac ]
#31337 11/10/2001 11:15 AM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Wheel lugs please. How many? | | |
#31338 11/11/2001 2:51 AM | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | Wheel lugs 6. I have some pictures but not home right now, I'll try to get some up later tonight. Thanks. | | |
#31339 11/11/2001 8:02 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | If REAL GMC, it won't have a 235 Chevy engine in it, would be a GMC 248 most likely. What about #'s on the hood sides? Door plate with GVW listed? Model/Vin there? Six lugs should be 1/2-ton, Yet my Big 2-ton GMC only has 6-lugs on it's 20" wheels, different than the 10-lugs on Chevs. Open driveline? Need more info I guess.  :rolleyes:
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#31340 11/11/2001 6:37 PM | Joined: May 2001 Posts: 1,908 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,908 | The wheel base dimension would help, if you don't have a VIN. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#31341 11/12/2001 10:18 AM | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | Ok, lots of good questions to help ID the truck...sorry, I haven't got the pictures up yet...busy at work the last couple days. (it's 1:13 am and I'm just sitting down to look at the site now). I'm off Tuesday, hopefully I'll get some vin info, wheel base meaasurement, info from vin plate, and some pictures up sometime on Tuesday. Thanks!  | | |
#31342 11/15/2001 3:29 AM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Careful there GLPerry! A 1954 GMC may indeed have a STOCK 235 in it. No you say? Au contrare! Canadian GMCs came with 235s in em! Ah HA! Who knew? #1) Measure the wheelbase from center to center 116" = 1/2 ton 125" = 1/2 ton longbed or a 3/4 ton #2) Count the lugs on the wheels. six is a half ton regardless of wheelbase. 8 is 3/4 ton if 125.25" and a one ton if 137". #3) In Calif, they remove the Serial number ID plate usually. If it's there, post the serial number which will read something like: 101-24-P (or C or S) then "Z", then a series of numbers. #4) Use the GMC Serial Number Decoder on my website to break it down. | | |
#31343 11/15/2001 4:15 AM | | Anonymous Unregistered | | Anonymous Unregistered | 6 lug long bed = the rare 1/2 ton long bed. | | |
