| | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31034 07/31/2003 7:28 PM | Joined: May 2002 Posts: 19 New Guy | | New Guy Joined: May 2002 Posts: 19 | Suddenly my right front brake is engaged even when not pressing the brake pedal. Oddly, it causes me to pull left when I stick the brakes kind of hard (maybe from fade on the right side?). I'm about to jump into it right now and see what the problem is but I thought I would leave a post in case anyone has had a similar problem. Thanks.
JON | | |
#31035 07/31/2003 9:24 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It sounds like your grease seal may have failed and the shoes are hanging up on the drum. Replace the seal and shoes, put in a new return spring for good measure, and adjust it. You may want to do both sides with new shoes so it pulls evenly.
#31036 07/31/2003 9:51 PM | Joined: May 2003 Posts: 53 Member | | Member Joined: May 2003 Posts: 53 | Make sure to check the rubber brake hose I have heard of them to break down inside and plug off causing brake to stay applied .
1956 GMC TF 1/2 ton 1955 GMC 500 model (Gumby)
#31037 08/03/2003 10:06 PM | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | Remember when reassembling after problem is fixed....... make sure all parts are free of contaminants or you may get lockup or grabbing upon aplication of brakes.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
