5 members (Oswald, DadsFirstPickup, Hotrod Lincoln, J Lucas, 1955 1 Series), 66 guests, and 1 robot.
Topics128,047
Posts1,055,622
#31034 07/31/2003 7:28 PM
Suddenly my right front brake is engaged even when not pressing the brake pedal. Oddly, it causes me to pull left when I stick the brakes kind of hard (maybe from fade on the right side?). I'm about to jump into it right now and see what the problem is but I thought I would leave a post in case anyone has had a similar problem. Thanks.
JON
#31035 07/31/2003 9:24 PM
It sounds like your grease seal may have failed and the shoes are hanging up on the drum. Replace the seal and shoes, put in a new return spring for good measure, and adjust it. You may want to do both sides with new shoes so it pulls evenly.
Paint & Body Shop moderator
#31036 07/31/2003 9:51 PM
Make sure to check the rubber brake hose I have heard of them to break down inside and plug off causing brake to stay applied . wink
1956 GMC TF 1/2 ton
1955 GMC 500 model (Gumby)
#31037 08/03/2003 10:06 PM
Remember when reassembling after problem is fixed.......
make sure all parts are free of contaminants or you may get lockup or grabbing upon aplication of brakes.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
