3 members (55shaker, baldeagle, Napco Man), 98 guests, and 5 robots.
Topics128,014
Posts1,055,328
Members48,419
#31025 06/16/2002 6:42 AM
On my 41 1/2 ton , I have radial tires , all the spring shakle bushings are new , and new king pins. It still has a litle looseness to it , I resently heard that if you run radials on those old staight axles , you had to increase, the " caster or camber" ,I cant remember witch is witch, tilt the king pin back a litle more , to make it work right with the radials. If anybody knows about this , please confirm or denie the corectness of this info for me. Thanks
Don
#31026 06/16/2002 10:13 PM
Don , you should have castor wedges under your front axle , in fact they should have been there all along .
I have radials on an otherwise standard front end and it steers fine , toe in is set at 0.
You cannot alter the camber with out bending the front axle , NOT a normal adjustment on these old trucks .
Is the steering box adjusted correctly ?
#31027 06/17/2002 1:33 AM
I have those wedges between my springs and axle , and steering box is tight, I thought mayby I might need two wedges, on each side .It doesent steer bad , it kind of has bump steer, my alignment guy said it might help to put smaller tires on it. Just hopping there was something else to try.
Don
#31028 06/17/2002 3:21 AM
What size tyres do you have Don , and do you have effective shock absorbers ?
#31029 06/18/2002 3:37 AM
The truck has original shocks , soon to bee reeplaced with tube shocks . I have P-225,-70 on the front .
Don
#31030 06/18/2002 4:39 AM
OK , personal opinion here Don . I think the 225 is a lot of tyre for the front of one of these trucks . You will need plenty of pressure to keep the tyre flex to a minimum.
Gas shocks will really help keep it tied down and pointed in the right direction.
My .02c worth . smile
#31031 06/18/2002 4:58 AM
Dusty, thanks , those tires sure look good though , I will keep working on it. First shocks, then smaller tires. Go from there.
Don
#31032 06/18/2002 5:00 AM
Don
#31033 06/18/2002 3:19 PM
I would get the new shocks on (and tires, if practical) before going to the alignment shop.
Fred
52 3600
69 C-10
