| | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31025 06/16/2002 6:42 AM | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | On my 41 1/2 ton , I have radial tires , all the spring shakle bushings are new , and new king pins. It still has a litle looseness to it , I resently heard that if you run radials on those old staight axles , you had to increase, the " caster or camber" ,I cant remember witch is witch, tilt the king pin back a litle more , to make it work right with the radials. If anybody knows about this , please confirm or denie the corectness of this info for me. Thanks
Don
#31026 06/16/2002 10:13 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Don , you should have castor wedges under your front axle , in fact they should have been there all along . I have radials on an otherwise standard front end and it steers fine , toe in is set at 0. You cannot alter the camber with out bending the front axle , NOT a normal adjustment on these old trucks . Is the steering box adjusted correctly ? | | |
#31027 06/17/2002 1:33 AM | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | I have those wedges between my springs and axle , and steering box is tight, I thought mayby I might need two wedges, on each side .It doesent steer bad , it kind of has bump steer, my alignment guy said it might help to put smaller tires on it. Just hopping there was something else to try.
Don
#31028 06/17/2002 3:21 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | What size tyres do you have Don , and do you have effective shock absorbers ? | | |
#31029 06/18/2002 3:37 AM | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | The truck has original shocks , soon to bee reeplaced with tube shocks . I have P-225,-70 on the front .
Don
#31030 06/18/2002 4:39 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | OK , personal opinion here Don . I think the 225 is a lot of tyre for the front of one of these trucks . You will need plenty of pressure to keep the tyre flex to a minimum. Gas shocks will really help keep it tied down and pointed in the right direction. My .02c worth .  | | |
#31031 06/18/2002 4:58 AM | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | Dusty, thanks , those tires sure look good though , I will keep working on it. First shocks, then smaller tires. Go from there.
Don
#31032 06/18/2002 5:00 AM | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | Dusty, thanks , those tires sure look good though , I will keep working on it. First shocks, then smaller tires. Go from there.
Don
#31033 06/18/2002 3:19 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I would get the new shocks on (and tires, if practical) before going to the alignment shop.
Fred 52 3600 69 C-10
