8 members (Wickedbass, tclederman, Rusty Heaps, Peggy M, TexasA&M48Truck, Wally / Montana, Gray_Ghost, UtahYork),
115
Mod | | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#3097 12/06/2004 12:40 AM | Joined: Jun 2004 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 103 | OK - This is a continuation of the "Knocking Engine" thread. I had an engine knock that refused to be isolated / identified. I checked all the suggested "remedies" to find the problem. No Help. Tear down revealed that the timing gear(fiber)in my 216 ci engine was missing 5 teeth! It was oil saturated which leads me to believe an aluminum cam shaft gear is superior to fiber? Just checking before the engine is assembled with all the "good" parts on hand. Thanks, BW | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | The alloy gear was a heavy truck standard part , it has potential to be a little noiser than the fibre , if matched with a worn crank gear , but you are not likely to loose a tooth off it . | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Thanks for your follow up. This is a really interesting result. When I had my new fiber gear pressed on, my machinist had to press it on until the clearance was correct. Pressing it on until it stops results in no clearance.
When I lost out on a fiber gear in a 235 years ago, it just died instantly. I am amazed that yours kept running. | | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Please replace both gears! There are kits out there. Isky ustta sell them Dusty is right they make more noise but their worth puttin up with
You ARE very lucky the thing ran and didn't mess up everything else | | |
#3101 12/06/2004 11:27 PM | Joined: Jun 2004 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 103 | Both gears are going to be replaced! I can't figure how the engine did not "lock up" with so many teeth missing on the cam gear. Trying to isolate the "knock" by pulling plug wires did not work. Compression checks were OK for a 53 year old engine. Connecting rod bearings were within tolerances. This is a new one for me and several "old time mechanics" that I know. We all ruled out timing gear problems because the darn thing would start and run with the VERY noticible knock. I guess there were enough "nubs" left on the cam gear to allow the crank to turn it? Go figure. Bob W. | | |
#3102 12/07/2004 12:37 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | And make sure the pieces of fiber gear aren't lodged in the oil pickup. | | |
