1 members (Danielbolt),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31003 10/29/2002 9:45 PM | Joined: Feb 2001 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 92 | I am finally reassembling my 270 and when I blasted the oil pan, I discovered that the previous owner had drilled a hole approimately 1/32 of an inch in diameter and then used a self tapping screw to fill the hole. Well I took the oil pan to a neighbor to have him weld the hole shut for me. he does not have the greatest eye sight in the world  , but he got it welded shut and in the process created another hole about 1/2" from the original  . Anyway, if I have to replace the oil pan, what engines are compatible? I believe that we will be able to weld the new hole shut also but just in case, I thought I should know where to look for a replacement. Tom
Whats down in the well comes up in the bucket, so watch who's KoolAid you drink.
#31004 10/30/2002 8:51 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | I would go the the local body shop and ask them if the could use their wire welder and fill the hole.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#31005 10/30/2002 9:36 PM | Joined: May 2002 Posts: 44 'Bolter | | 'Bolter Joined: May 2002 Posts: 44 | bluebird, All the oil pans for the GMC 228, 236, 248, 256, 270 and 302's are all interchangable. The only thing that you will have to be careful about is that the oil pump cover matches the the pan. The deeper GMC pans had different pump covers that allowed the scupper float to reach down to the correct depth. And if you already have the deep pan, the oil pump cover that is installed will not allow a shallow pan to fit. It does sound like a re-weld of the pan you have now will work. If you go this route, I would recommend painting the inside of the pan with Glyptal. Eastwoods has this product and it has worked very well for me. It will keep the pan from rusting on the inside due to condensation. (At least any thin spots won't get any thinner from the inside  .) Hope this helps
"The Operation of GMC trucks is normally smooth and steady, with no loud rattling, knocking or unusual noises. A good driver will quickly become accustomed to driving a GMC truck and will get the feel of his vehicle regardless of his engineering knowledge."-TM10-1563
#31006 10/30/2002 10:07 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | I tried to weld a crack in my valvecover last week. I tried a MIG and brazing. The metal kept getting brittle and heat cracking next to the weld. I got tired of chasing cracks and gave up. Make sure that the re-welded pan has no hairline cracks that will seep oil.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#31007 10/31/2002 1:14 AM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | Why don't you try solder or braze?
if it dosen't need fixed, break it
#31008 10/31/2002 3:15 PM | Joined: Feb 2001 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 92 | Thanks for the advice. I am almost certain that this hole can be welded correctly and filled. My only concern is its proximity to the oil drain plug. This concern is not great, but it does exist and since it does, I thought I should investigate my options.
I think that I will go to a shop down the street and ask them to fix this for me rather than go to the neighbor again, I just feel bad for my neighbor. I dont want to offend him since he has always been so generous with help.
Anyway, thanks for the advice.
Tom
#31009 10/31/2002 5:21 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Sheet metal this thin can be mig welded, but you have to have a rig that will set pretty low on the heat range, most aren't. If you want to get past the cracking issue, get someone to tig weld it.
Fred 52 3600 69 C-10
#31010 11/01/2002 4:46 AM | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | fixing holes in oil pans is extremely difficult. Usually, a crack reapears after some time. If it were me, I would toss the pan and get a new one. By the by, do you have any idea why the PO drilled a hole in it?
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#31011 11/01/2002 6:12 PM | Joined: Feb 2001 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 92 | For the life of me I cannot figure out why he would do that?
I have seen some work out in the field where a person may have a small hole and rather than fix it, they drill it out to make it bigger and put a sort of plug in. I have not seen this with engines mind you, but it is not uncommon when you just need to fill a hole easily. Maybe this is what he was doing?
Anyway, I think I will continue to attempt to fix this hole while looking for a new pan.
#31012 11/01/2002 6:24 PM | Joined: Oct 2000 Posts: 108 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 108 | Bluebird,
I'm with Fred T on this one get it tig welded. I just had a crack on my Fulton visor tig welded. It came out great. no heat warpage. And the crack was right where the side bracket mounts to it too. | | |
