| | | Forums66 Topics128,087 Posts1,056,377 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30870 02/19/2004 5:10 PM | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | Hello, A guy I work with poured power steering fluid in his gas tank. I guess the bottles look similar to those of gas treatment. The labels were old I guess and the mistake was made. He has filled up the tank to full and waiting to see what happens. Do you have any Idea wht might happen? What would you do?
This is an older I am guessing carburated Nissan truck. | | |
#30871 02/19/2004 5:46 PM | Joined: Sep 2002 Posts: 115 Member | | Member Joined: Sep 2002 Posts: 115 | PS fluid is basically ATF with some additives. Putting it in a computer-controlled engine might make it run funny, but in a carb engine it will just make a little smoke. Diluted one bottle to a full tank, the smoke may not even be noticable.
It certainly won't do any damage.
Joe | | |
#30872 02/19/2004 5:53 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | People used to use it for upper cylinder lube and to clean out carbon deposits. Today's additives work far better.
Fred 52 3600 69 C-10
